Hey you can use the standalone T stat housing, or do like the #4cooling mod on the 8v motors and mod it to put the T stat near the cam sensor(where the freeze plug is):thumb:im working on making one for my 2.4. the only issue im running into so far is the stupid t-stat housing thats actually part of the intake, because my throttle body needs to go on that side because the car is being converted to RWD. im making a plenum style intake out of the old one, its off a stratus, the long stupid runner one.
i will definatly look into that, but plumbing the upper radiator hose to the back of the head may be a pain in the ass alsoHey you can use the standalone T stat housing, or do like the #4cooling mod on the 8v motors and mod it to put the T stat near the cam sensor(where the freeze plug is):thumb:
do you know were i can get an aftermarket intake manifold?if its from a '01 2.0 then yes, but your TB setup may be different?
hey you understood me when I said using the "standalone" T stat housing right?i will definatly look into that, but plumbing the upper radiator hose to the back of the head may be a pain in the ass also
