Hello All. It's been a while since I've been here. I had to store the 87 Shelby Charger about a year. (Its a red Dodge one) I went to get it back on the road and it failed smog due to the gas cap. I bought a new one and all of a sudden the car ran like crap. It's throwing all sorts of codes. EGR, O2, MAP...
To the matter at hand. While fixing a vacuum leak, I bumped the pig tail wiring harness plug for the air temp sensor. Ignition was off. Both wires, brittle and cracked already, broke off. When I unplugged the remainder, it disintegrated. I could not tell which wire went to which side of the connector/sensor.
I soldered the connectors to new leads but both wires are black with a purple tracer. I plugged them in and now I get an air temp sensor code too. I switched the sides and the code still exists.
The two identical wires disappear into the harness. I'd rather not un-do the entire thing to follow these.
I have an new plug on order.
If both leads to the plug are black with a purple tracer, does it matter which side they go to?
If sides matter, how do I know which goes where?
Thanks. :shrug:
Thanks. :shrug:
