I have a 1991 daytona Shelby w/ 2.5 t1 5 speed.
I have recently started to have a problem with my AIS. One second it is stuck open the next it is closed. Sometimes it works fine. It is all over the place with no reason. I have replaced it and still the same thing is happening. For now it is unplugged in the closed position and I have to create a vacuum leak to start the car untill it warms up. Once it warms up I plug the leak and then it will run OK. I do have a few other problems that might or might not be related. I think it slipped a tooth on the timing belt. My tach goes in and out. Every once in awhile it will miss on a cylinder (probably timing). Random spark knock ( sometimes it will happen @ 5 lbs. boost other times I can run it to 14 lbs with no knock( within seconds of each)) My friend who is a mechanic but does not work on turbo's too much thinks it may be my ECU/ ECM is going bad. Any Ideas???:bang head:bang head
