I decided to make new thread to eliminate confusion and 4 pages of reading and scrolling.
Updated list and pictures...
https://picasaweb.google.com/104468385751464109627/DropBox#
I am ready to consider offers.
2.5 common block with pistons crankshaft and matching bearings. valve spring compressor. piston ring compressor. engine cylinder hone. half shaft cores. spring compressor. two fly wheels for manual 1 machined. large brake master cylinder and calipers. control arms. bathtub cylinder head. hybrid transmission with just a few thousand miles and (built by cliff ramsdell, with per overland's -if anyone remembers him- bearing plate at .210 thickness instead of most .180, and phantom grip) and 555 transmission. distributors and hall effect pickups. a f gauge. fuel rail and injector harness. alternator unknown condition. 3 starters I known condition. two water pumps unknown condition. 1 water pump new out of box. l body ralley springs. charger and turbo badges. 2 valve covers. pulley puller and harmonic puller set. Timesert re thread kit for 11mm(I think, I can verify if needed) head bolts. shortened shifter for 555 and 520 transmission. waste gate actuator. square tooth camshaft pulley. adjustable round tooth camshaft pulley. round tooth timing belt. engine and transmission mounting brackets for l body. vacuum solenoid banks. new transmission mount inserts . Wiper motor unknown condition. fuel pressure regulator. bench vise. wire shelf storage racks: local pickup only. record turntable. beat up helmets. nunchucks. finish sander. circle saw. 1 inch tow inch. table top drill press. quarter inch air hose pvc. very plastic boxes. pegboard tool organizer. aluminum crab wheels from daytona c s.(for 225/50 r15 tires) 2.2 common block oil pan needs welding for hole. 1 piece aluminum intake. otc scan tool kit with ford cartridge. engine lift: local pickup only. engine stand : local pickup only,3 logic modules (2 socketed with upgraded cals), one power module.
Sorry for any typos and punctuation errors. I dictated the list with my android phone
Hybrid trans $400
555 trans $125
Common Block $100
Piston set $480
Crank and bearings $120
Adjustable cam sprocket $50
Everything else is for offers. I'm moving across the country and want to take as little as possible. I have a lot going on, but I'll be in between semesters in about two weeks, and that will be the fastest turnaround on shipping. I have a solid history of communicating shipping expectations, and have never left anyone with surprises. Local pickup is in Winchester VA 22601. I can transport smaller parts to Brambleton, VA (not too far west of Fairfax) on my workdays if anyone has plans to be out there.
And as always, the best way to get ahold of me is [email protected]
Thanks for looking
Hybrid trans $400
555 trans $125
Common Block $100
Piston set $480
Thanks for looking
