I've got the poly bushings, I need the metal spacers that ride inside the bushings.
james
sory it took soooo long to get back to you do you still needs this,if you do I have everything you need! lmkIm needing the two steel bushings that go into the rubber bushings and the spacer in between, I really need the bolt two. I hope someone has these, its holding the omni up. thanks,
James
