Who is this someone?
Why wouldn't you just go get the part that is correct for your vehicle?
Is this so that you get a long 1 piece passenger axle instead of the troublesome 2 piece axle? What car?Im replaceing my passenger side axle and someone told me when i buy the new one to get one for an automatic instead of the manual... Is this true or false??????:shrug:
91 2.5 Lebaron 5spd andyes my buddie said it would b a one peice instead of a two???Is this so that you get a long 1 piece passenger axle instead of the troublesome 2 piece axle? What car?
Detobias explains it well. Just get a non-turbo (2.5TBI, 3.0, ect) passenger axle. This will be the long 1 piece axle.91 2.5 Lebaron 5spd and yes my buddy said it would be a one piece instead of a two???
so get it for a non turbo and same year? this will b the same spline, size and a one peice? There wont b any problems since im just changing the one side then?Detobias explains it well. Just get a non-turbo (2.5TBI, 3.0, ect) passenger axle. This will be the long 1 piece axle.
Thanx thats what i need to know much appreicated.So your whole situation is you want to eliminate the 2 peice passenger side axle shaft for a single shaft? If so, use a non-turbo or automatic shaft from what I found, all 1987-1995 one peice long right side axle shaft, from any of the following: Shadow, Daytona, Lebaron, Aries, spirit. All 555, 568, 530, 543, 523, 413 with lockup, 604, 670, transmissions use the same inner shaft spine size
lol LOVE the ChryCo interchangeability !!So your whole situation is you want to eliminate the 2 peice passenger side axle shaft for a single shaft? If so, use a non-turbo or automatic shaft from what I found, all 1987-1995 one peice long right side axle shaft, from any of the following: Shadow, Daytona, Lebaron, Aries, spirit. All 555, 568, 530, 543, 523, 413 with lockup, 604, 670, transmissions use the same inner shaft spine size
