1 - 2 of 2 Posts
put the stage 2 cal in from FWD. i noticed 2nd gear would pull real hard then third-fifth had no balls. well today i turned everything off (radio etc) and pulled a long third gear to listen. boost gets to about 10-12 psi then stops and falls. when it does this i hear something pretty much blow open and you can hear air rushing. im pretty sure it might be the BOV but the spring is so stiff already im getting surge during regular driving. any advice for a BOV that wont give surge for a DD but will hold 15psi? and how do i find other leaks? is there a way to fog test it like you can do with vac lines?
thanks,
nick
I made an adapter from a quick disconnect for air tools to a barbed male connnector- connect it on a hose and set to 20psi or whatever you want to be safe to and listen for a hiss. The entire system has to be sealed at the turbo intake.
1 - 2 of 2 Posts
