I lost my tachometer/radio/dome light but 25 (10amp) fuse on the kick panel was good, found no 12volt coming in and found a fusible link open in the engine bay with a 9655 on it, anyone with a wiring diagram or know what size the link is?
CaR is a 1990 Dodge Daytona ES V6
TIA!!!
EDIT: The link is black if that matters, I have a 1990 Wiring diagram and its different from what the actual wiring in my daytona is, Would a 1989 diagram be different? My tona has a wrap around dashboard (newer style interior). I just want to splice a F540 or like but need the amperage!
Discussion Starter · #2 ·
Well I found minimopars take on the hypalon fusible links: Electrical Issues - MiniMopar Resources
I will double check but the center of the link was black while the insulator had grey which equates to about 50amp which seems high (hince will double check during daylight) but will replace it with a MAXI fuse and socket.
Hope someone might find this helpful in the future.
