After I put my 3" exhaust on my stock Garrett T1, I ended up with the dreaded boost creep. Hard to believe with a Garrett, but it did happen. I pulled off the turbine housing and opened the wastegate port from 7/8" to 1". The swing valve barely covers the hole, but it spools up fine and now the boost creep is gone. However, I still have a 2# boost spike whenever I shift at WOT. The RPM doesn't spike as I set both my A413 clutch packs to minimum clearance and raised the line pressure. I'm wondering if this is just inherent to the design. Anyone else seen this or have any ideas?:shrug:
