vacume block to a .020-.030 orifice, then to a Tee fitting. Run one side of the Tee to the soleniod. And the other side goes to the wastegate actuator. My guess is that you don't have the restrictor. Or you have your solenoid/wastegate plumbed wrong. If you don't have the orifice installed, you won't restrict flow enough to bleed off the pressure to the actuator. That's what the solenoid does.
However, if you do it this way, you'll be back to running stock boost levels.
Wink
Wink
