K guys i just took in my shadow and had 600 dollars worth of front end brake work done and now my brakes go to the floor when i am driving or idling or what have you! They will stop the car but i dont like the idea of them going to the floor is this normal! I dont think so. When the ignition is off then they are rock hard! which is what i want. So what do you guys think the problem is a hose on backwards?
They replaced the rubber hoses, calipers, master cylinder, rotors, and brake pads. I have taken a look and there are no leaks that i can see but there is fluid leaking out of the caps on top of the brake fluid resevoir (hope thats the way you spell it)? Any suggestions!?
