I am at the point with my 2.2 CB T11 rebuild that I need to know the set up info for degreeing the cam to the crank, how much lift at start, and what degree the crank should be at?
What are some of the mods so people know what you are working with, if you are looking for a stock timing, I know that NAJ has some good pics, but if you have mods that would need it to be off, then there should be somebody here that would know how to figure that out
.040 over pistons, ported intake & exhaust manifolds, 52 mm tb, 3" exhaust & swing valve, stiffer valve springs. Bottom end, pistons and rods balanced.
