Picked up what looks to be an 89 casting of a 782 head with a roller cam. Cam has what I've measured with verniers 450 intake, 445 exhaust lift. 400 base circle. (doesn't seem to match any stock cams with max 430 lift.)
Asked on the SDAC Facebook page about using square cam aproket on this cam/head and consensus was heads are the same (possibly minus the squirters for slider cam, have not checked caps yet.)
Linked me to donavans dodge garage which doesn't mention any difference in cam timing between the two sprockets, just states yes you can use a roller cam in an earlier head.
Turbo dodge parts faqs looks like stole the info from DDG. As it's the same.
What say you guys.?
Old posts on TM do state there is a 4 deg retard by putting a square on a round and vice versa. But can't find anything concrete.
Should I just throw this head in with my square sproket and cross my fingers? If it's no good advance the cam 1 tooth at a time? Or just buy an adjustable cam gear to start?
View attachment 284084 View attachment 284085
What say you guys.?
