I don't believe it would work, at least not easily. I don't have any personal experience with them, but looking at the Chilton manual it appears it would be a poor design. It is designed to handle only a portion of the power from the engine, not full drive power. I am assuming it isn't as robust as a standard diff. Adapting the input shaft is the next obstacle. It uses a torque tube to transfer power, not a standard driveshaft with U-joint. Some machining would be required to get it to bolt up. Next, it has an overrunning clutch, which is what allows it to transfer power only when needed. It does appear that the overrunning clutch is a separate module from the diff, and just bolts to the front. I wouldn't imagine there would be any aftermarket support for it, and it is an open type diff. (no LSD). I was thinking the same thing, but after looking at the exploded view, I would probably go with a different diff. Look on ebay for a LSD E30 BMW diff. (or similar)That might be a better choice. Plenty strong and lots of part support. Then adapt axles and driveshaft to fit. You would still need a Caravan rear axle assembly, especially hubs.
