You know, now that I think about it, did you remember to align the oil pump gear with the intermediate shaft properly? If you installed a new oil pump, I think with the timing belt and all shafts at TDC, the slot should be parallel with the crankshaft. If you didn't align the oil pump, then you won't necessairly be 180 off, you could be 70 degrees off or something.
