car: 89 daytona cs 2.5 bored 30 over garret tII a555
Well i took my car out of winter storage about 3 weeks ago, put some fresh 93oct in it and it ran awesome. up till about a week or so ago. I was driving and it would just start running like crap about 3k like timing was being pulled or something im not sure. anyways i noticed i had a code 14 at the time map sensor voltage error, ok so i checked the map sensor i had power going to it from the computer 5v and out of it to the computer , vac lines were good. before i checked the voltage inputs/outputs i noticed if i would turn the car off disconnect the map and tps sensor it would run fine for about 2 minutes tops, pull good and everything. So fastfoward i have now put stock champions in it, i had gr4s in it. Seemed to run good, old plugs looked good i gaped right, regaped the champions to 34. Car ran great for about 4 miles then it ran like crap after that would pull to 4k though. Its not as severe as fuel cut when i would overboost in 4th hit 18psi open dp. Im not sure what to do, the cal was socketed witha 2.5 cal no cel mod. Ive always had 93 in it. thoughts? I stoped at a gas station filled her up with more 93 ran great for a while then went back to crap.
Thoughts?
Thoughts?
