1 - 5 of 5 Posts
My lower pcv line is dripping oil occasionally, i was wondering if i should install a catch can, if so what would be the best way to go about doing it and what should i use? Thanks
depends, does it bother you to be dripping oil all over?
the easiest solution is to cut a hole in the lid of a soda bottle and stuff the tube in. or you can buy some rather esxpensive purpose built canisters from summit.
well i can race at the strip if its dripping oil, thats my main intention is to add a oil catch can to stop it from doing that
you mean that it's dripping oil from around the clamp hose clamp. Just take it off, clean it up nice, throw some RTV on it if you want, and reclamp it good and tight. If the hose looks bad, maybe replace that too.
its leaking from a breather that i have on the lower pcv line, because i no longer have the old T1 airbox in it
1 - 5 of 5 Posts
