nodoleblue,
I tried to respond to your "Timing Belt Cover Wanted" thread, but it said I did not have the proper privileges to respond for some reason on that thread.
I have 1 available that was removed from my 1984 Dodge Daytona 2.2L/135 Ci single point TBI (Non-Turbo), car if you absolutely need it now instead of September. I have pics if interested, it is of course not in new condition, but the bolting points are all complete, it will clean up well (a heating with a heat gun, or set it in the summer sun, allow it to get good and warm, then install both top and bottom pcs, and it will of course take a new set and fit right). It has been off the car since 1994 and in a box in my garage.
Also, the center large lower left soft 2" plastic grommet where I am sure the PS belt rubbed that area in the pic lower left long ago, can simply be popped out by hand & replaced if needed with an easy to find cheap 2" plastic Floor pan drain plug (I just found 1 brand new still in the pkg of 5 I purchased a month ago), sitting on my current build parts table I will also
include, then you can pop out the old 1, trim a 3/4" hole out of the center with an exacto knife blade, and push it in. Will see if my pics post up here.
$65.00 plus the actual shipping cost, I am in Northwest. AZ here (it is not heavy and can get it in a small box well protected after I pull the 1 bolt that attaches top pc to bottom, I take Paypal), or I can even list it on ebay and forward you the buy it now auction listing (to an e-mail address), if you wanted it done other than direct to you buying/shipping. That would be up to you.
Let me know if that is the right part (Part numbers are on the pics-up close upper/lower and the lower shows the 2 pc full assembly part # below the lower part #), and if you want it, drop me a zip code, and I will find out the shipping and we can get it to you asap. (I have more of the under hood plastics if needed).
