90 daytona 2.5
it does not have an air charge temp sensor
my stage 3 computer would really like one
i dont want to take the head off or the intake manifold off
problem is if i drill the hole there will be little aluminum shards inside the intake manifold, PROLLY NOT A GOOD IDEA
hmmm...any genius black art mechanic tricks around this?
i was thinking i could put the sensor where the main vacuum port for the fuel pressure regulator, map sensor, etc.. are and then connect all those vacuum lines to the brake booster vacuum port instead
