I lost my cluster lights, chaged fuse, still gone, re changed fuse, nothing. Headlights still work as well as the indicator light for my fog lights in the interior, It seems as if there is no power directed to the cluster anymore. Any help would be appreciated, thanks.
I have wiring for a 91 Shadow and this shows 3 differant fuses and power feeds to the cluster.My suggestion would be to check ALL fuses with a test light to check for power in and out,be sure the key is on and the lights are on and you will probably find a faulty fuse.
Also be sure you did not accidently turn your dimmer down.
Thanks, I will check my book and see if the 93 has the same ammount of fuses, I already checked the dimmer, its ont that, although I'm not saying Im not prone to do such stupid things. Thanks again, I'll let you all know what it is.
_Kevin
