1 - 2 of 2 Posts
ive recently purchased a 86 glh omni and dont know alot of the history but i know as soon as you move your foot alittle bit the clutch becomes fully ingaged theres no happy medium either engaged or not i looked and theres no adjustment at the fork end of the cable theres also no cam at the top of the clutch pedal to adjust slack but clutch doesnt slip ive herd of installing washers at the fork end to adjust if cable is stretched any ideas guys cllutch almost gone or do i have other probblems? thanks:confused:
· Administrator
It is ossible you have a pressure plate problem but according to Alldata you have an automatic adjuster.Be sure it is operating properly. the teeth on the clutch pedal/adjuster need to be lubricated and be sure the spring is in place and the cable is routed properly.
If the cable is suspect why not replace it? I replace mine every 50k regardless, 1 tow bill and being stranded at midnight on a Sunday was enough.
1 - 2 of 2 Posts
