1 - 2 of 2 Posts
270639
1 04295585 1 L PEDAL, Clutch
04188668 1 PAJKGHS
2 05206237 1 L PAD, Pedal
04019715 1 PAJKGHS
3 04019706 1 L SPACER, Pedal Shaft
04019716 1 PAJKGHS
04188659 1 S
4 04019707 2 BUSHING, Pedal Shaft
5 02073632 1 WASHER, Pedal Shaft
6 06030373 1 RING, Pedal Shaft, Lock
7 04188669 1 LPAJKGH ADJUSTER, Clutch Cable Pivot
04188660 1 S
8 04019695 1 ADJUSTER, Clutch Cable Position
9 04188666 1 SPRING, Clutch Cable Adj.
04019749 1 DAMPER, Clutch Pedal Adj. Spring (Not Illus.)
10 04505539 1 L CABLE, Clutch Pedal
04505341 1 PAJKGH
04377770 1 S
11 04377825 1 ISOLATOR, Clutch Cable
12 03593446 1 GROMMET, Cl. Cable Dash Panel
13 06100050 2 NUT, Cable Mtg. Plate, M8x1.25
14 04188101 1 PLATE, Cable Mtg.
06100098 2 SCREW, Cable Plate Mtg., M8x1.25x20
15 03759944 1 RETAINER, Plate
16 04295369 1 CLIP, Cable
17 04188664 1 L BRACKET, Cable Mtg.
04505673 1 PAJKGH
04431157 1 S
18 02266820 1 BUMPER, Pedal Stop Brkt., Except L,S Body
04019709 1 L
02266820 1 S Up To 1-16-89
04471941 1 S After 1-16-89
04188673 1 S BRACKET, Clutch Pedal Stop
19 05206244 1 GROMMET, Cable Retainer
20 05206245 1 RETAINER, Cable Lock
21 TRANSAXLE, (Rererence)
22 SHAFT, (Refer to Gr. 5)
23 PAJKGHS BRACKET, (Refer to Gr. 5)
24 06031447 1 NUT, Cable Mtg.
25 04295759 1 BUSHING, Clutch Rel. Shaft, Inner
04295438 1 Outer
26 04295426 1 SHAFT, Clutch Release
27 04295428 1 FORK, Clutch Release
28 04295477 1 L LEVER, Clutch Rel. Shaft
04511039 1 PAJKGHS
29 04202378 1 BEARING, w/Sleeve, Clutch Release
30 06500510 1 E-RING, Shaft Outer Bushing
31 06500951 1 E-RING, Lever To Shaft
32 L BRACKET, (Refer to Gr. 5)
33 04188653 1 CLIP, Clutch Cable Adj. Spring
what do you need?????????????
1 - 2 of 2 Posts
