1 - 6 of 6 Posts
WTB Turbo Dodge clutch pedal switch bracket and a 6 wire brake switch.
I do not want the 2 wire clutch switch just the bracket.
I intend to use the 6 wire switch inplace of the 2 wire so I can add a clutch start along with the factory cruise control kill feature. The 6 wire will do that because it has both Normally Closed and Normally Open circuits.
Jeff
Just so you know, the clutch safety switch(2-wire) will cut out the cruise if it's engaged. I installed this switch on my '89 Shadow, but be warned. the motor will "tach up" a little when you first press the clutch in.
yep, I know the 2 wire will kill the cruise (it's N/O switch), but I want a 6 wire because it also has N/C for brake lights and I can use that to make no start unless the clutch is pushed in.
Does anybody out there have a parts car with manual trans and cruise control? I need the clutch switch mounting bracket please.
1 - 6 of 6 Posts
