Fault Code 21
Synopsis
Description: Oxygen sensor signal stays in neutral region too long
Power loss light: Off
Limp-in mode: Engine allowed to run rich, but prevented from running lean
Possible Causes
Bad connection or wiring - Check the wiring and connections between the sensor and the logic module (or SMEC). Clean and regrease any corroded connectors with dielectric grease and repair any shorts. Look for melted wire insulation near the exhaust manifold. An open connection will cause this fault code.
Bad oxygen sensor - Replace the sensor which is located on the turbo housing near the down pipe (for turbo) or on the down pipe near the exhaust manifold.
Diagnostic Method
Trigger Parameters
- In closed-loop for 718 seconds (11 minutes, 58 seconds)
- Sensor output stays in the neutral region for more than 21 seconds
Results If Component Fails
A fault code 21 is stored. The circuit stays in closed-loop and the logic module will still monitor the oxygen sensor signal and allow the engine to run rich, but prevent it from running lean.
Fault Code 52
Synopsis
Description: Oxygen sensor output indicates rich too long
Possible Causes
Bad connection or wiring - Check the wiring and connections between the sensor and the logic module (or SMEC). Clean and regrease any corroded connectors with dielectric grease and repair any shorts. Look for melted wire insulation near the exhaust manifold. A shorted connection to any positive source will cause this fault code.
High fuel rail pressure - See the Diagnosing Your Fuel System page.
Diagnostic Method
Trigger Parameters
- In closed-loop
- Sensor output indicates rich for more than 715 seconds (11 minutes, 55 seconds)
A fault code 52 is stored, the circuit stays in closed-loop, and the logic module will still monitor the oxygen sensor signal. If the condition persists for four times what it took to set the code, the logic module will allow the engine to run rich, but prevent it from running lean.
Fault Codes - Mini-Mopar Resources
Looks like both are O2 sensor issues, replace/grab from junkyard, and retry.
