BAD SELLER!!!!!!!!!!!!!!
My check engine light is on.. Code 24 keeps coming up.. I have changed the Throttle Position Sensor 3 times with no luck.. What else could be the problem.. Any help is appreciated. Thanks.
Its on a '92 T1 Daytona
Code 24 is TPS voltage high or low.
You need to backprobe the signal and signal return lines at the TPS with it connected and the key on/engine off.
OR/DB and BK/LB wires.
What is voltage reading?
Normal closed throttle voltage will be anywhere from .35 - 1.00 volts.
Post back and I will tell you where to go from there.
R.I.P Dennis Jarvis
oops
have you got another idle speed motor kickin around ? - if so try it
once upon a time I got a code for idle speed , I bought a new 1 , installed it and had no improvement - checked with dealer to be sure I had the right 1 - he said their all the same -
so after a little thought I swaped the throttle pos sensor
presto it now ran fine - I never had a code for throttle pos sensor but it had to have 1 to fix it right - along with the idle speed motor - ya I tryed swapin back the old 1 and it ran like crap again
