1 - 5 of 5 Posts
:bang headneed help my car is hesitating and the idle is up a lil. she is throwing a p0122 and a p0123. im pretty sure its the tps wiring but not sure just put a brand new tps in it a couple days ago and she has been fine up until today. also if anyone knows a good place to get diagnostic code list that would be nice so i dont have to ask yall every time
P0122 Throttle Position (TP) Sensor Circuit Low Voltage
P0123 Throttle Position (TP) Sensor Circuit High Voltage
· Administrator
I asked for the year to verify this TSB applies to you.
Throttle Position Sensor SRT4
Part Numbers:
04606196A$
Issue Description:
The typical customer concerns include check engine light on (code P0123 - throttle position sensor voltage high), rough idle, stumbles and engine surges. Before ordering a TPS please check the engine wiring harness take-outs to the TPS by monitoring the TPS voltage and wiggling the wires to the TPS with the engine running. If the voltage spikes to 5.0 volts, the wiring to the TPS maybe broken inside the insulator and intermittently open. Then determine where the broken wire is located and repair only that portion of the harness/connector. Repeat the wiggle test to verify the repair.
______________________________________
1 - 5 of 5 Posts
