I have a 89 2.5 Turbo Caravan and I am rebuilding the top end. I am also removing the emissions gear.
My confusion is with the vacuum lines. I see that some people run the large nipple on the Intake Manifold to an vacuum block and then patch those in to the MAP, The, Barometer, The FPR, The WGS, etc...
If the intake is normally a vacuum, then when it is boosted does it not become pressurized?
### Ignore this, found the answer###
Also is there an advantage of running a vacuum line from
Intake > Barometer Sensor > Map Sensor.
Rather then
Intake > Barometer > Capped
Intake > Map Sensor
Rather then
Intake > Map Sensor
