90 daytona 2.5 turbo
i need to drastically shorten the large radius turn the pressure tubing makes when it comes out of the saginaw power steering pump. it just sticks out too far. i'm thinking there might be a fitting which can replace the tubing and make a much harder right angle, which i can then connect to the original tubing somehow, even if i have to cut it.
does anyone know the technical name for the power steering pump pressure fitting? instead of a flare it has a little bump with an oring.
anyone know of a 90 degree adapter which will screw right in and provide something i could reasonably connect the cut end of the original tube to?
is the tubing aluminum?
