1 - 2 of 2 Posts
Hello all, I have installed a switch that lets me control when the radiator fan turns on. My basic setup is a toggle switch from Advance auto parts. I am simpling running the ground from the coolant temp sensor on the water box through the switch. With the switch off, the computer controls the fan, with the switch on the ground circuit is broken and the fan turns on. The problem I am having is when I turn the switch back off the fan stays on. When addjusting the timing and pulling the temp sensor, I noticed that the fan stays on even when you plug the switch back in and you have to turn the car off to get the fan to shut off. Is there anyway to turn the fan off with my switch or do I need to wire the switch up to something else like the fan relay? Thanks for the help
1 - 2 of 2 Posts
