1989 Dodge Daytona Shelby | 2.5L I4 Turbocharged | Automatic Transaxle
Been having a crank no start issue with my '89 Dodge Daytona Shelby for a while now. I have been chasing potential causes for weeks but to no avail. Its too a point where I need some advice on where to go to further diagnose and solve my issue. Today I left with the information that the injectors are not firing due to no power to the injectors. I attached a NOID light to all injector connectors and nothing happened on all of them when I tried cranking the engine.
I went to the ASD relay to test that and the relay works, it clicks when the key is on/engine off and I can hear the fuel pump turn on for a second. I even took the Relay off and manually actuated it for a sec and test resistance readings and everything was in order. 12V is also being supplied from the red wire, which comes from the positive terminal, to the relay.
Another test I did was to see if 12V was being sent from the Relay, through the DG/BK wire, to the fuel injector connectors. When I turned the Key to the on position I read a brief flash of 12V on my multimeter at the injector connector.
I also tried checking the wires which supply constant voltage to the injectors, The 2 wires that go from the fuel rail harness connector straight to the SMEC(in the Haynes manual they are labeled the WT and TN wires), to see if there is any voltage coming from those wires and I read nothing on my Multimeter when I turned the key to the on position.
At this point I am under the impression that the computer is sending the signal to pulse the injector from the relay through the DG/BK wire, but a constant supply of power isn't being sent to the injector from the WT and TN wires attached to the 14 prong SMEC connector.
If anyone has any idea on what could be causing this issue I would greatly apricate your input. I am not very good at diagnosing electrical issues and interpreting results from electrical tests yet, so if you notice anything that seems wrong in my understanding of the EFI system then please let me know as well! This is my first project car and I am still trying to learn everything I can about every system in this car.
Other information about the car's condition: 2.5L Turbo, has spark, good compression(cylinder 1: 130; 2: 130; 3: 140, 4: 140), timing is good as well(might need further adjusting, we think its close enough to get the car running), I rewired the whole fuel rail harness and I am more than confident that it is all wired correctly.
