1 - 12 of 12 Posts
R.I.P Dennis Jarvis
It's located by the air box and looks like a 'Y' If you look thru the 'Y' you will see a aluminun insert restricting the air flow too a pinhole.
R.I.P Dennis Jarvis
tried the dealer and no luck and he would not give me the part number what a jerk!
Douchers at the Chrysler dealer, who knew? They wanted to charge me 100 bucks for a MP headgasket.
Ill be on the lookout for those orfices dennis
R.I.P Dennis Jarvis
bump
You should have no problem making that "Y" with a restrictor.
Is the restrictor/orifice located before or after the "Y"?
R.I.P Dennis Jarvis
Discussion Starter · #7 ·
after
Then just add a "Y" and directly after a 3/16" restrictor that you can get in the vacuum connector section at Advance or Autozone.
Vacu-Tite 3/16" Vacuum Restrictor Part# 47311
R.I.P Dennis Jarvis
Discussion Starter · #9 ·
thanks
R.I.P Dennis Jarvis
Discussion Starter · #11 ·
Just trace your vacuum lines aroud the cruise control and look for a y connector. Look inside if you see anything that looks like it restricts air flow thats it.
Don't know if an 87 uses the 88 cruise control system or not. I know that they used a Vaccum ejector. If your interested, here is a link to how it works.
http://www.turbododge.com/forums/f4/f14/344996-what-vaccum-ejector.html
R.I.P Dennis Jarvis
Discussion Starter · #12 ·
just got one from midnighttoker
1 - 12 of 12 Posts
