1 - 6 of 6 Posts
Does anyone know if i absolutly have to make a custom computer box cooled by a 12volt fan so it wont burn up? So i can put a Cold air intake on it. ANY input would prove very helpful... Also its a 93' 3.0 in a shadow
they are not needed unless you are running in the desert. it just doesnt get hot enough. if you still want on, cut a hole into the side of it, and take a computer fan and screw it into the side of it to blow air directly onto the heat sink. i did that at one point.
frank
i live in texas and it gets pretty hot and all i did was remove the cover so the ecu was exposed.
never had a preoblem ever
Ok thank you guys... you guys help alot!
Shoot, you don't even need it in the desert. Roger ran his out in DEATH VALLEY in 125 degree temperatures, and never had a bit of trouble.
1 - 6 of 6 Posts
