Daytona High Boost Pull
1718 Views 7 Replies 5 Participants Last post by  Turbo_Z
3rd gear and part way through 4th gear pull
1989 Daytona Shelby T2
3bar CAL, +40 injectors, 2.5" mandral bend exhaust, cat deleted with a dynomax muffler, manual boost controller set to 20psi
Sorry for filming it the wrong way on my iphone :( easier to see the cluster in full screen.
1 - 8 of 8 Posts
You running 20 psi with a stock intercooler, just curious?
Yes, everything to do with the engine is stock, forgot to mention im running a T3/T2 clutch from FWDPerformance. I was trying to run 25psi during the summer but was continuously knocking on pump gas, so im running 20psi and happy with it.
AF at 20 PSI?
I don't have a wide band so I can't tell you what it is, I'm just using an air/fuel gauge. Don't need the wide band until 30psi ;)
sure don't drowning the engine with fuel so you make 20 PSI HP at 30 PSI :rolleyes:
I would rather not mix fuel with my oil and strain my turbo so hard for nothing. You can add 100 WHP to a new Evo X by fixxing the fueling at the stock 23 PSI. Barely running over 100 MPH in the old days at 30 PSI sucked.
He's using one of Robs cals so its probably fairly reasonable. Were it one of the FWDP cals I agree there would be a lot of power to gain by turning down fuel pressure or similar
rob from boost button are his cals GOOD
1 - 8 of 8 Posts
