Hey guys, I had 2 questions about the rear axles on the daytonas as I've got a lead on one and wanted to make sure it's going to bolt up fine, idk if the donor is going to have the solid version I've read about or not, but I'm just speculating until I go look at it.
A) Are the axles between an 89(#4421231) and a 92 (#4626171) bolt up interchangeable? I know the part numbers are different between them but I'm kinda hoping it's a superseded number but same part situation.
And
B) Does drum/disc matter? From some reading I've done on the forum it appears to mostly determined by the bolt on spindles if I read correctly and the axle itself doesn't matter.
I apologize if I missed where that was confirmed in my searching and thanks in advance. :)
