Some of you may have noticed that I have been missing for a couple years. Most of that is due to my job requiring me to travel a lot, and when I get home, there's always a project waiting to be done, so the cars go to the bottom of the list. I haven't been able to work on the Daytona for a couple years, but finally have it back into the garage. With the virus keeping me from traveling, I finally have time to work on it.
For years, I have wanted to upgrade the tires and wheels to something more current, which would allow me to also upgrade to bigger brakes, without breaking the bank. This is going to be my track day car, but also a fun street car. The main post is at:
www.turbododge.com
If you've never looked into a Quick-Jack car lift, I highly recommend them. They make raising and lowering really easy and seem to be really stable. I have the 7000 lb version and have used it to lift my Titan, with no issues.
The Daytona came with the standard 205-60R15 tires, as the Laser. Years ago, I upgraded the Laser to aftermarket wheels, which I really liked, but wished that I had wider tires. When I took it to the track, I bought a cheap set of tires, in 215-60R15 size, which tended to rub a bit, but worked OK, as long as you didn't turn them to full lock. At the time, I figured that I was out of luck, in the upgrade department. I have since learned that 15" tires are pretty much going away, so I decided to dive into this again.
I first had to decide on a tire wheel size. Doing a lot of research, I learned that the SCCA Miatas are required to run 225/45R17s, and there are a lot of used ones out there, which will keep track day tire cost down.
I first needed to figure out if they would fit under the Daytona. Normally, I would go to the U-Pull It yard and buy a used one, but decided to take a chance and bought a set of these, off eBay, for under $300, delivered:
FEDERAL SS-595 TIRE 225/45R17 (4) NEW TIRES 225/45/17
The next problem is finding wheels and big brakes. The biggest issue is the bolt pattern. The Laser/Daytonas use 5x100mm lug spacing, which is hard to find big brakes for. I had heard that the wheel bearing hubs, from a Grand Caravan will bolt up to the front spindle, with a 5x114.3mm spacing, which is 4-1/2". That moves us into Mustang territory, which will give endless options.
I went to RockAuto and found that Durago sells PN 295-13074, for '89-'95 Grand Caravans, for $40 each.
They bolt right in and use the same splines as the original axle shafts. The main difference is the size of the centering area, which are 2.9". That will come into play later. I also like that the lugs are longer, and use the same threads as the old hubs.
Of course changing the front will also require changing the rear, which is a different animal. I found that the Caravan came in an AWD version, which were used on Grand Caravans from '91-'95. Raybestos sells PN 712125 for $174, which is pricey, but gets rid of the wheel bearing/spindle setup.
I know, since it won't have a driveshaft inside it, I will need to fabricate a dummy setup to keep it compressed. That shouldn't be an issue. One benefit is that the new setup isn't as long as the old. This should allow me to fabricate a new mount to the rear axle mounting plate.
For the front struts, I am using Rich Bryant's BC Coilover Neon setup, which is much shorter than the original Daytona/Laser struts. This will require that I make a custom strut mounting plate, which I am currently having waterjetted. More on that later.
Excuse the rust, but this has been sitting outside for over a year. I guess powdercoating doesn't stop rust.
'87 Daytona Trackday Build
I have decided to start posting pics of the build I started on in 2012. I haven't posted, because there wasn't much progress, until lately. I will apologize if I post too many pics, but feel that too many is better than too few. OK, let's start at the beginning. In 2012, I decided that I...
