The rear hubs and brakes are not going together the way I had originally planned. At first, I wasn't sure where to locate the center of the hubs, but decided to just center them where the original spindles went.
I made a flange that would allow me to drill 4 holes to mount the hubs. These are the original spindle holes.
I had designed the outer mount for a vertical orientation, but the rear axle mount takes up too much space horizontally, so there wouldn't be room for the heads to spin.
Rotating the hub locates the bolt holes far enough away from the axle for the bolt heads to clear.
I widened the flange to make more room for the holes.
I used the old spindle to center the hub. Fortunately, these are thru holes, not threaded, so they don't have to be as precise.
This aluminum block and steel plates locate the tire in the same location as the original.
Sensitive content, not recommended for those under 18
Show Content
Sensitive content, not recommended for those under 18149.6 KB Views: 36
