what are symptoms of a bad MAP sensor on a TBI car?
the fsm doesn't go into any diagnostics on how to test the MAP.
it had idle issues recently and it's cleared up when the egr stuck open.
anyway it'll idle for days until you start getting onto the throttle. when in gear and cruising, if i hit the throttle the car will jerk, buck back and forth. in an attempt to settle the motor i hit the clutch and let off the gas to neutralize everything and let it coast. when i do this the car stalls out. when it had its idle issues it's actually never stalled out.
it'll start right back up again though and idle fine.
this only happens when it's under load.
what da problem is?
what da problem is?
