When I was doing my compression test I just pulled the main spakr wire off the coil.
Noticed a few times that coil had enough jam to Jump a spark across a 1.5" gap to the fender.
After I did comp test, got the air box mouse house cleaned out, I restarted it.
Noticed at idle the Tach is now showing 3500 rpm...
Did the coil sending 20K+ volts randomly to ground kill the Tach signal?
Still runs absolutely fine.
