Spark and Fuel, and that's about all you need. It occurs to me that you should check the vacuum lines again. I have had the MAP sensor go bad and it actually ran better after I unplugged it. With the map sensor disconnected it will go into linp=in mode, but that's better than nothing.
It kind of sounds like a vacuum problem and the MAP sensor is "a priority circuit": so that's why the vacuum needs to be checked again. Fluttering the gas pedal is a clue.
Sometimes a vacuum leak is only obvious after very careful checking. It is hard to imagine what is wrong, but working on the Chevy will only get the S-10 working, unless you are lucky enough to have some litte magic elves work on it while you are sleeping, but that only happens in fairy tales.
NAJ has a good, systematic approach. I have never had to check fuel pressure myself, it either works or it doesn't in most cases. It is good to check the fuel pump electric connector/plug at the gas tank because sometimes they are loose and charred by the resistance. Some people conjecture that the long distance wiring run can cause a voltage drop that can affect the pump. It is probably something simple, but it will only seem that way after you fix it. Good luck.
