You're going to need the digidash dash and its two connectors. Lots of cutting and splicing wiring involved.
Analog to Digital Convertion.
Forget the wiring diagram, they are all wrong. Just go by the COLOR of the wire and you'll be fine. You have to find a constant 12v pos for the red wire, you can find that wire in the head light control nub. You don't have to worry about display dimming. You don't have to worry about parking brake indicator lamp, because you already got the brake warning lamp.
Digital Dash
FUCTION COLOR Notes
1 Headlamp-high beam lamp Red/Orange
2 Right Turn Signal Tan
3 Left Turn Signal Green
4 Tachometer Blue/Grey
5 Engine Oil Pressure Grey
6 Distance Sensor White/Orange
7 Display Dimming Yellow/Orange
8 Air Bag Black/Brown
9 Water Temperature Purple/Yellow
10 Instrument Panel Illumination Orange
11 Driver Door Switch Black/Blue Doesn't work
12 Not Used Not Used
13 Not Used Not Used
14 Power Loss Warning Lamp \ Check Engine Light Black/Pink
15 Not Used Not Used
16 Fuel Pacer Lamp Green/Orange Doesn't work
17 Seat Belt Warning Lamp Red/Blue
18 Brake Warning Grey/Black
19 Parking Brake Indicator Lamp Black/White
20 Ground Black/Green
21 Fuel Gauge Sending Unit Blue
22 Engine Oil Gauge Grey/Yellow
23 Ground Black/Orange
24 Park Warning Lamp Black/Blue Doesn't work
25 12 volt Ignition Feed Blue/White
26 Battery Red
Sheet 2: Analog
Analog Dash
FUCTION COLOR Notes
Power Loss Warning Lamp Blue/Pink
Air Bag Black/Brown
Brake Warning Black/Grey
Ground Black/Orange
Seat Belt Warning Lamp Blue/Red
Tachometer Grey/Blue
Left over from Digital Dash
Fused Battery Feed Red
Park Warning Lamp Black/Blue Not Needed
Not Used/Water Temperature Not Used or Red/Blue Doesn't work
