I made a fuel injector tester/cleaner. I thought I would show you what I did. I mounted a T1 fuel rail and injectors to the top of the wooden frame. Then I wired them together with a modified fuel pump to turn on at the same time. I just have to apply 12 volts. The pump was from my Sunbird but I added a fitting on each end to run outside the tank. The 'fuel tank' is the small plastic container on top. It must be mounted above the fuel pump to allow the gas to drain down and prime the pump. I may have to remove the lower fuel line for a second to get the gas flowing, though. I can run fuel injector cleaner through the injectors. I can see the spray pattern as well to see if they are spraying well. I can snap in my T2 injectors as well. Under the injectors i will have some empty water bottles to catch the fuel. I did this because I'm too cheap to buy new injectors unless I really have to. Enjoy.
