1 - 2 of 2 Posts
airthis intake available on ebay bolts directly to the throttle body and then with no modification hooks right to the ecu air duct. It's the only intake I've ever seen that works with the factory set up OR you can do like I am and put a 3 inch computer fan from a pc on you ecu air duct and then run the intake hose to where your wiper blades are and draw cold air from there via included duct
View attachment 276705 airthis intake available on ebay bolts directly to the throttle body and then with no modification hooks right to the ecu air duct. It's the only intake I've ever seen that works with the factory set up OR you can do like I am and put a 3 inch computer fan from a pc on you ecu air duct and then run the intake hose to where your wiper blades are and draw cold air from there via included duct
I used a intake off a Acura Integra and had it in front of the trans getting cold air...
Vehicle Motor vehicle Car Automotive design Personal luxury car
1 - 2 of 2 Posts
