I installed a remote start on my 2004 neon, when I connected the locks and it would unlock but not lock then I seen post saying I needed a resistor on the lock and unlock signal so I did that and the lock side still did not work then I noticed that the lock side of the factory door switch did not work either so I checked the door switch and it is working but will not lock the doors pass side is the same however the factory key fob will lock/unlock Im afraid I killed the bcm anyone have any ideas?
I am not familiar with Neons nor do I have any wiring/service info, however...
My Sisters Hyundai developed the same issue months after having a remote start installed and I advised her to go back to the place that installed it.
My suggestion would be to disconnect the remote start, reconnect all factory wiring and see if the door locks function as they should.
If not, you will need to connect a DRB3 or equivalent and see if there are any BCM codes stored.
