I have a 92 Daytona V6. Does anyone know where I can find the driver and passenger side door trim? They both cracked from rubbing against the fenders. I believe it was caused by either door sag or the front clip shifting.
Tire Car Vehicle Wheel Motor vehicle
Car Vehicle Hood Automotive tire Automotive lighting
Mopar part numbers 5261966 (R) and 5261967 (L). These parts were "paint as required," so any used ones you find will have to be painted (red notwithstanding).
Marty's Arizona Parts site shows the left one in stock:
Font Watercraft Line Slope Parallel
1 05261320 2 BRACKET, Applique Attaching, Quarter Panel Upper
2 05261492 1 BRACKET, Applique Attaching, Door Upper, Right
05261493 1 BRACKET, Applique Attaching, Door Upper, Left
3 05261318 2 BRACKET, Applique Attaching, Fender Upper
4 RIVET
06032731 20 For Attaching Upper Applique Bracket
06502689 16 For Attaching Door Applique
06031115 14 For Attaching Lower Bracket to Side Sill
5 05261964 1 APPLIQUE, Fender Rear and Sill, P.A.R. (front section stamped 4538192-3),
Right
05261965 1 APPLIQUE, Fender Rear and Sill, P.A.R. (front section stamped
4538192-3), Left
6 05261966 1 APPLIQUE, Door, P.A.R., Right
05261967 1 APPLIQUE, Door, P.A.R., Left
7 05261968 1 APPLIQUE, Sill and Quarter Front (rear section stamped 4538196-7), Right
05261969 1 APPLIQUE, Sill and Quarter Front (rear section stamped 4538196-7), Left
8 05261324 1 BRACKET, Applique, Fender, Sill and Quarter Lower, Right
05261325 1 BRACKET, Applique, Fender, Sill and Quarter Lower, Left
9 06501067 32 RETAINER, Applique to Bracket
10 06031390 12 RETAINER, Applique to Wheel Opening
11 04451394 1 SPOILER ASSEMBLY, Liftgate
12 04451416 1 SPOILER ASSEMBLY, Aperture Panel, Right
04451417 1 SPOILER ASSEMBLY, Aperture Panel, Left
13 8 WASHER, not serviced
14 06025002 AR NUT
you need item #6 the door molding
5261966 R 5261967 L
do not have
will fit 1992-93 Daytonas
if nobody on this site has it try here:
www.car-part.com make sure you are looking for the "ground effects" and not the standard door molding
