1 - 2 of 2 Posts
Will the axles on my 89 shelby be a direct fit to my 88 shelbyZ?
After only one week of being able to drive the car i just grenaded an axle. :bash:
thanks,
From Donovan's Dodge Garage:
"In 1987 Chrysler upgraded axles in all but the L-bodies to a larger, heavier splined axle (both automatics and manual transmissions)
83-86 small spline axles (weaker)
87-93 large spline axles (best)
All years had the same spline on the outer end of the axle (at the brake rotor)
Just the inner spline changed as better transmission were produced.
All G/H/K/J/AA/E axles are 100% interchangeable between bodies and years except for the years noted above due to spline changes on the transaxle differential end. The axles were made by several vendors over the years with the turbo cars having the strongest ones."
http://www.thedodgegarage.com/ The absolute Bible for FWD Chrysler cars.
1 - 2 of 2 Posts
