1 - 8 of 8 Posts
I'm trying to revive a Consulier whose MOTEC ECU is not responding. I have several ECU modules from the Shelby Daytona and a partial wiring harness with both connectors for the Shelby ECU. I'm looking for a wiring diagram/schematic which will help me replace the MOTEC with one of the Shelby ECU modules so I can get the engine running. Between their two connectors, the Shelby units have considerably more pins than the MOTEC, so I expect I will have to spoof some input and/or output lines to satisy the Shelby unit. The Shelby ECU modules that I have are 036 or 635 units and were used with the car before it was converted to the MOTEC ECU. A wiring diagram and suggestions for the most simple solution to getting the engine running will be much appreciated. Once I can verify the engine runs, I'll worry about any more extensive measures for best performance
Welcome To TD!!!
I can help you with the wiring schematics but I need years.
The Consulier is a 1990, but I don't know from which model year the drivetrain was taken. I would presume not more than a year or two prior to that. I can check for an engine number if I knew where to look.
Everything I read says the car used the common block 2.2L Turbo 2.(1989)
Does your engine controller have one 14 pin connector and one 60 pin connector?
1989 would be just right for the drivetrain and the ECU modules do have the two connector (14 & 60) pin configuration. Fortunately, I found the appropriate mating connectors in a box containing some of the original wiring harness.
Discussion Starter #8
ECU numbers (4) are:
P4532036
4517637 (two of these)
5233246 (however, this one also has another sticker saying "635" and a handwritten note indicating that the board has been socketed and the chip replaced.
I haven't cracked the cases yet.
1 - 8 of 8 Posts
