Hey guys,
I just got a used Autometer EGT off ebay, and I just realized that its missing a part that threads into the manifold. The thing in the pic.
Anyone know where I can get such a thing without buying a whole probe kit? I have everything I need except for that piece.
Thanks,
Nick
There is a place near me that has stuff like that. It is a hose and rubber supply place that specializes in making replacment hydrolic (sp?) hose. Any place that stocks pipes and fitting would probably have something that would work.
I have the same gauge you do.
summitracing.com sells it :
Auto Meter Replacement Probe Fitting Kits: ATM-5255 - summitracing.com
Good god! Someone at summit really likes their dope... I could swallow $10-$15 maybe, but $40? Get bent Summit.
I guess I'll just keep looking for it online. Worst case I'll just buy a whole new probe kit.
Thanks for the input,
Nick
yes most probes are simple 1/8" diameter and use a common compression fitting to hold them in place
a good hardware store should have something with e.g. 1/8" NPT on one side and a 1/8" compression (prolly brass, altho if the have steel or SS then certainly get that) on the other
something like Grainger 3LW51 which is for a 3/16" compression (which they want 24$ for ?) grainger.com
from wiki:
"The relatively low melting point (900–940 °C depending on composition) of brass ... "
