1 - 5 of 5 Posts
Anyone have elec schematic for 1988 dodge daytona shelby z? washer pump not working,rear defroster not working, and how do you take mirrors off or apart to work on them.:confused:
Does the light illuminate on the rear defrost switch when turned on?
Disconnect the washer pump connector and have someone operate the washer and check for power and ground.
What do you need to do to the mirrors?
The mirrors themselves are not serviceable.
Appreciate the diagrams.Pump works, made a jumper from battery to pump. No power on wire connector didn't think to check the ground.Haven't done alot of checking on the rear defroster yet. More concerned with washer pump right now. Power mirrors do not work ,they won't hardly stay in place manualy. Will any other car mirrors work.
Hey NAJ!
Could I get a copy of those? I see the one for the defroster here:
http://www.turbododge.com/forums/f4/f21/143574-heated-rear-window.html
do you have one for the wiper?
On Wiper switch harness, when I ground the brown/white wire, the sprayer works...
have power to white wire at defroster, grey & orange have good ground but no power to the bk/rd wire...Where is this coming from???? 2 Fuse-able links at the rear hatch test good-am I missing another one?
(trying to repair a hack job from a radio/alarm install & removal)
1 - 5 of 5 Posts
