Re:FREE - Electronic Gauge Cluster
I don't seem to being getting much feedback about getting the electronic cluster working. So...here is the deal for anyone interested. I have two electronice clusters. Both in working order with no fault codes. I will give one of them FREE ( include shipping) to the person who can provide with the info, part, etc. that will get me a functioning one in my car (90 Daytona ES). I have tried both of them. I get the same problem. Fuel gauge shows full (half a tank),and water temp shows 3/4 high (cold engine). All other funtions appear to work correctly, including oil/amp. gauges, tach. speed,warning lights, etc.
What I have done so far; Tried both dashes, using factory manual -matched wiring to conform with both J & G models (Le Baron/Daytona) I have tried four body computers (2 out of J models & 2 out of G models), and the mech. cluster works fine on all gauges.
Note: Not all of the body computers showed the same problem in relation to the issue I am having.
J body #1 computer from same car I remove one of the elctronic clusters from shows no gauge function at all. I am assuming it is bad.
J body #2 computer shows the gauge problem noted above, then after a few minutes oil and temp drop to zero and warning lights start blinking.
G body #1 computer same as J body #2 (except this is a computer that was rebuilt last year).
G body #2 computer shows issue noted above, however, gauges remain functioning unlike G #1 and G #2.
I feel it my be a body computer issue, but how to know that or know which computer would work with the cluster? I have traced the wiring and do not find but a couple of differences between the J & G, and I have made the corrections with no change in the results. So I don,t think the wiring harness is the issue. Currently, I back with the mech. cluster which is working fine.
So... any takers?
