The readings you have for your ACT sensor are correct.
I am gathering that right now your problem is a no start, is this correct?
If so get back to basics, to start you require fuel, air, ignition and compression in the right amounts at the right time, what is missing?
Earlier you stated that static rail fuel pressure was at 40 psi which is low.
Static rail pressure should be 53-57 psi and hold, with the engine running rail pressure will drop 1 psi for every 2" HG applied to the FPR.
If fuel pressure is low that is where you need to start unless there is also a lack of spark and the pump is not running then you may have an ASD or HEP problem.
